from ac to dc voltage drop
1iwilly
Sr. Member
Dec 7, 2008
924
657
103
64
so my cobra 2000 gtl on the internal power supply shows 14.20 volts when the radio is keyed it only drops to 14.12
then when i switch to the external power supply set at 14.30 when the radio is keyed it drops to 13.52 volts but the volt on the power supply at the terminal doesn't drop they only drop inside the radio only drawing 2.3 amps so my question is why the 1-volt drop tr-41 was upgrade thinking the 3756 regulator
The problem is the only thing between your power supply and your radio such as:
DC power cord or DC power cord connections(including any inline fuse(s) in the DC power cord. (I should have written "Fuse connections" of the DC power cord.)
Dirty contacts of AC/DC switch on rear panel(if equipped)
David
Reactions: unit_399
Small size wire and longer lengths rob more power. Inline fuses really make a difference depending on the quality of the fuse holder. I had a 100 watt ham rig that would dim the panel lights with modulation until I beefed up the fuse holders.
Reactions: Crawdad
here are what my reading look like off the external =14.34 at end of plug=14.34
connect the plug to radio at terminal =14.06 why the voltage drop i' tapping on the 2 pigtail terminal key up radio drops =13.39
Just for shits and giggles measure the voltage drop across each fuse. Not the fuse itself but rather the wire immediately before the fuse itself. The contact relies on a simple pressure fitting and those were the type of fuse connectors that I had an issue with on my ham rig.
ok i found the problem something to me to check the dc plug adapter look at the pic it's the terminal is bad i took my 148 check the voltage and look no drop
i guess the previous owner never use it
Reactions: Captain Kilowatt
