Galaxy DX959 "swing" help
There is one reason and one reason only on God's green earth to reduce your carrier and enhance the radio's 'swing' on AM transmit.
An amplifier.
All linear amplifiers tend to exaggerate the carrier and diminish the peak power. Modding the radio to bring the carrier down so the amplifier isn't straining is half what's needed. Preserving the radios full peak modulated power when the carrier is reduced serves to counteract the amplifier's tendency to suppress those peaks.
Set up right, the radio should sound as good amplified as it does barefoot.
But for a radio you will use barefoot? Waste of time.
If the waveform is altered through the amplifier that means it's a nonlinear amplifier. Saying that all amplifiers are non-linear is patently untrue.
Reactions: 543_Dallas
An amplifier.
The purpose is for a linear. I do appreciate your input NOMAD. Hoping to come see you soon!
  • @ Hambones amps:
