GOOD SIZE ROTOR
  • Thread starter Thread starter steal man
  • Start date Start date
S
steal man
Guest
DO ANYBODY KNOW WHERE CAN I FIND A ROTOR THAT HAS TEN SQUARE FEET OF WIND LOAD
</p>
Hello Steel Man:
Yeah shure look here at the Hy-Gain Ham 4 Rotor.
www.hy-gain.com/products....did=HAM-IV
This rotor is rated at 15 Square Feet, but this rating is only when the rotor is mounted inside a tower frame, and uses a external Thrust Bearning at the top of the tower, NOT mounted on a mast. Hy-Gain Rates this rotor at 7 1/2 square feet if its mounted on a mast.
Mounting the Rotor in the frame of the tower and using a external trust bearing is the best advice I can give. I have a Crusader 10K, 5 element yagi beam up for only 6 months before it made a Hy-Gain Ham 4 Rotor turn into mush from the strong winds we have here in the Mojave Desert. But is was mounted on the mast, and only lasted 6 months.
If you really have a 10 Foot Square, the best advice is to go the next bigger rotor, the Tail Twister T2X its only about a 100 dollars more, but is a investement that when the beam is up there, you won't have to be changing the rotor which is usually the weak link in a beam installation.
Jay in the Mojave
www.a1antennas.com
</p>
steal man, you might want to post in the Forum Swap Shop section to see if anyone has a Ham lV rotor with control they want to sell. I think someone listed one not too long ago for around $200 bucks (which is a good price). I recently sold one in excellent condition to a local for $250.
Also, like Icom 706 said "try Ebay", but be cafeful...
Hossless
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=hossless>hossless</A> at: 5/18/04 3:58 pm
I have a buddy here local that has a 6 element Gizmotchy on a 47' tower being turned only by a light duty rotor (I think about 3.5 windload). He uses a thrust bearing to take the verticle load off the rotor. He has used this small rotor to turn the Gizmotchy for about three years with no problems until now - the gears finally crashed and burned. A thrust bearing is the only way to go.
Hossless
</p>
check out www.universal-radio.com/c...surot.html
Yaesu G-800sa rotor with a 16sq. ft. wind load for $339. This is an excellent rotor for a good price.
Their G-250a is $259, it is a 10 sq. ft. rotor. Another nice rotor.
Hossless
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=hossless>hossless</A> at: 5/18/04 6:56 pm
  • @ heartbreaker3473:
