Grounding base antenna
BigLou , I meant No disrespect in my comment , I don't roll that way . But what Capt K said I didn't know your mast situation & the H2O . It's just me I have 2 (6-8') ground rods on my 30' Galv push pole . Just so happens they are in my wife's flower beds , so when the irrigation comes on ... they get H2O also . Believe me I didn't plan it that way !:whistle::LOL:
Reactions: S&W357
Just from what I’ve read here, all I have to say is, “Huh?!”‍♂️
I want to hang a firestik on a pole that is stuck in the ground and try to protect it from lightning strikes. Any simple suggestions?
I want to hang a firestick on a pole that is stuck in the ground and try to protect it from lightning strikes. Any simple suggestions?
Is this what your planing to do with the Firestick?
http://www.rfcafe.com/references/po...nds-Grounded-aug-1959-popular-electronics.htm
Gary's right ! Ask away ! Welcome to the forum ! As he suggested try making a wire antenna ( if you have room ) I learned that when I first joined , they work awesome ! 73 & God Bless , Leo
Reactions: binrat
Good deal! Thanks for the information. I will be running a standard run of the mill cb radio and a vintage VHF MURS with the same PL259 connectors. Yes, two different antennas for different frequencies at least (how far?) apart. So now, what KIND (rating, type) of coax should I run for the radio(s)?
BTW: How do I test SWR with a small handheld cb used as mobile and the same with the MURS?
Reactions: 357magnum
