Damn Slow... did ya go in and buy a lottery ticket after you changed yer shorts! sheesh!
“Near”, as I live in Fort Worth
I dunno. Chances are that if your station got hit by lightning with the re bar used as ground rods; then the moisture in the concrete would expand and turn to steam at a rapid rate and either crack it everywhere - or explode if there is enough water in it. Dunno. When trees get struck by lightning, they explode from the same cause.At my last house I had driven my ground rod just outside my radio room for grounding purposes so it was nearby.
Moved into a different house and was looking at where to drive a new ground rod (once I go to store and buy it) and when I was outside I noticed that there are some metal form ties sticking out of the concrete about 1foot above ground level outside right near where I'm setting up inside.
Wondering if you can ground to a metal rod sticking out of concrete house foundation as I feel like somewhere I remember someone grounding to rebar encased in concrete?
Just thought - boy that's a lot easier than buying a ground rod and driving it into the groundGuessing it may not be as effective but figured I'd ask.
