Hello I am new to the Ham world so please don't Flame me.... If I don't ask I won't learn..... Are licensed Hams allowed to own "Export Radios"
Thanks.
Thanks.
Thanks CW... I will look into those radios you suggest.C W Morse said:There are no actual laws as to possession of "export" radios. The laws apply to SALE by vendors and OPERATION of said radios on frequencies the operator has no authority on. So, yes, a ham may use most any radio that meets mimimum spectral requirements. He can even make one himself!
But the question I have to ask is: WHY would you want a CB-lookalike radio with "channels", beeps and squeaks and echo--none of which have anything to do with ham radio? In general, a non-channelized 10 Meter radio that IS approved (see FCC certification sticker on the back) is much better than one of those so-called "export" radios anyhow!
To each his own, if I am about to pursue the ham hobby, I would look into an all-band, radio such as the Icom 706 or Kenwood TS-480. You can get *some* of these used for not much more than one of those bootleg exports. Caution: Do NOT use your ham radio on CB (dual-use)! It is illegal, and while it is tempting to do so, it is not a good idea. Use HAM equipment for ham, and LEGAL CB equipment for CB. The two are different, OK? Hope this helps.
CWM
Thanks CDX 126... Technicians Class.... I am waiting for my call sign.CDX126 said:Hey Drifter, did you get your HAM license? If so welcome to the wonderous world of HAM.
Novakor..... I intend to buy a Ham Rig that does everything. It sould be something I can grow into.... Do you have any suggestions for a good base type, mobile, and hand heldnovakor said:Drifter now that your a ham why settle for an export radio when you could have sooooooooo much more,legally.
Try to get a rig that you can use all the way around,and still have room to upgrade for HF.
There are a number of radio on the used market that are under the $450 dollar range.Congrats on your new privileges.
73,Stu
Drifter said:Novakor..... I intend to buy a Ham Rig that does everything. It sould be something I can grow into.... Do you have any suggestions for a good base type, mobile, and hand heldnovakor said:Drifter now that your a ham why settle for an export radio when you could have sooooooooo much more,legally.
73,Stu
CDX126 said:I am drooling over the FT-817nd, it has all bands from 160- 70cm. Good QRP radio and you can run a amplifier if you want( it's only 5 watts). It's a good field radio, being fully self sufficent. I also think it would be a nice Base or Mobile setup. I am also looking at the VX7R, HT Triband( 6m,2m,70cm). Real nice for local or other modes like moon bounce or space station work. It's also multi-mode. Both radios are real low power, so if your looking for 100-200 watts, you will need to look else where.
