I just got a 220, and when i turn it off the plate voltage meter shows 1kv in hv setting, and fan is still running?? can use some help??
Number15 said:One of the mods done was a filter capacitor block replacement, and was running fine at 220v and when i changed it to 110v, then it showed 1kv one the plate voltage meter,
STOP! Back up, if it was working properly on 220v before you made the change and now there is a problem, reverse your steps back to where it was working correctly.
If you can get it back to the point where it works on 220v, re-do the wiring change to the power transformer.
I live near sacramento CA, and im trying to find a good tech to look at the sb220 but no luck yet, Thanks for all your help.
SAVE YOUR MONEY, you can fix it!
