Help locating one of these (dual gang pot)
Eldorado828
UDX-828 in the Lonestar state (WDX-828)
I Support WorldwideDX.com!
Feb 21, 2016
4,921
9,764
523
The Panhandle of Texas
Good morning fellas. I'm looking for one of these dual pots with on/off switch like this one. It's a ranger style echo board pot that came with an aftermarket board. This one had a bent shaft so did my best to straighten it but internally its damaged. Anybody have one they can part with?
Thanks
Barkett has a bunch of dual controls used in stuff made by RCI.
Just doesn't seem to have that one. The center shaft is a 10k audio taper, hence the "A" suffix after the "103". Probably the echo volume knob.
The "104" 100k section is a linear taper pot.
Makes me wonder if you couldn't get by with the more-common 50KA/50KB control used with the echo boards built into a lot of radios. Also shows up as the volume/squelch/power control in mobile radios.
Here's what Barkett has: http://stores.goldeneagleradios.com/potentiometers/?sort=featured&page=1
Might have to settle for a substitute. The particular combo of resistance values in your control doesn't seem to be commonly offered for sale.
Unless Ken has it.
Reactions: Eldorado828
Thank you nomad, I'd already tried barkett but looked again and nothing. I thought maybe amongst the many here it could be possible. I appreciate it sir.
