A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
A vertical properly mounted and grounded to the aluminum sounds like a winner. A SS 102" would probably work quite well with that much groundplane directly under it.
Almost all tubular metal antennas are built from aluminium tubing. So what's the problem?
The main issue is not whether the aluminium is good for a RF ground, it's about the physical strength of the bodywork to support a mount with an antenna on it.
