Help
Thanks me to . I know there is mixed feelings about Dustin and his work but I must say speaking for myself my comp 29 is a animal barefoot when I run my amps that thing is a monster.
It might be a good idea before you "lock and load" on the connections...
Check for that looseness and even clearance - make sure the knurl seats and the feruule under it is not loose...
Give then a good tug to see if the "knurl - notch and Teeth" are seating and you can't twist the coax sheath (not the knurl twist on - it's ferrule the one on the PL-259 that slides into the connection that has both the center pin and outer shield) make sure you can't make it move or make it shift.
  • - if that's the case, you're going to need to make some changes to the SO-239 PL-259 connectors
  • - that may require retightening or rework/redo the SO-239 at that component of your system so you can provide clearance to the PL-259's screw "depth" - if it's too long - replace with a different brand of PL-259 or even to the extreme of grinding off / filing down that knurl ring to threaded portion - but it looks like hell - so better to replace with a less deep connector - even if it means using a different patch cord
I've seen a few PL-259's that their outer Knurl thread-depth is TOO deep in depth, preventing the notch of the PL-259 and teeth of the SO-239 - not mating making a SOLID sealed - SEATED connection - it will come loose if you fail to check it on occasion.
Don't want to see you lose your monster to a bad connection...
Mostly wear and abuse. It also happens when someone leaves a solder blob on a coax connector and jams it in the socket.
I replaced a relay in my amp because of this recently. Intermittent RX loss was the symptoms. I could key the amp a couple of times with the foot pedal and the RX would come back. I figured it had to be the relay but I was wrong. The connector under my work bench that goes out to the antenna was loose on the center conductor.
Hopefully it fixes your problem.
I have a radio that does this, I'm going to have to take a closer look. Thanks
UPDATE. My 15 year old jumper died. I tried 2 new truck stop junkers both bad . Moral of the story don’t go cheap . Dustin fixed me up with new jumper solder amphenol ends with big grey chord. I’m 10-8 again.
Reactions: 543_Dallas
