....without buying a ready-made attenuator? Here's the problem:
All 10x probes are de-rated with frequency. The PP215 probes that came with my siglent scope have a 600v DC rating, but the chart says that at 27MHz and up, they are only rated at 25v. 12w into 50ohm is already 24.5v, so any higher, such as the antenna jack of a dual final radio, exceeds that probe rating.
A transmission line probe is tempting, but the typical 21:1 transmission line probe with the 1k series resistor would require a 5w 1k resistor if I were to tee into a 100w 50ohm system (since 100w across 50ohm is 71v, and 20/21 of that across a 1k resistor would be 4.54w). I could do that, but I don't like my probe tips getting hot. If I wanted to use a 1/4w resistor to make my TL Probe, it would take a 20k series resistor and a 401:1 multiplier with a terminated 50ohm cable. Thats not practical.
So then I thought, what about using the 10x probe and another voltage divider at its tip. If I know I need a total of 20kohm to be able to use quarter watt resistors, using (6.7k+6.7k)/6.7k for a 1:3 divider will let me safely probe that 71v of RF, but I still need to tell the scope its a 30:1 probe and this all seems kinda janky.
I know some bird meters have a sample port, but I assume that attenuation is far greater meant for a spectrum analyzer input rather than a scope, never owned one to know.
What method do you use to probe high power signals? I feel like I am missing something really simple here.
Anyone know where I can find a decent 150w 20dB attenuator without spending $600? It doesn't have to go to 8GHz lol.
