HT Battery Cross Reference List
towerdog
one-niner-seven
Nov 18, 2009
644
134
53
NC
I would like to start a cross reference list of what batteries will fit which HT's.
I think there is alot of deliberate confusion surrounding the issue as well as alot of horsecrap as nowhere can I find such a list, more like vendors not displaying the battery part number but just the application, for a price and then the same battery for another application, for much more $$$. Feel free to help and contribute.
Reactions: ALVIN and KiethS
These radios.........take CNB-151 / CNB-152 series packs
Alan 42
Albrecht AE201
Dragon Sy101 501, SS 201, AH 100
Cobra HH-45, HH-46
Cherokee AH27, AH50, AH100
Eagle Spitfire 454
Intek SS 201
Magnum 1010, 1012
Maycom AH27
Midland 75-820, 75-822
Standard C150, C158, C228, C528, C628, C450, C558, C28A, HX260, HX268, HX240, C112, C412, C520, C620, ADI AT200, AT201, AT400, AT401
Titan RPSY
(I am sure more exist but thats all I have found...mostly from pictures)
Available for these radios are
CNB-151 7.2v Ni-Cd battery
CNB-152 12.0v 800mAh 3" tall, Ni-Cd rechargeable battery; provides 5 watts of TX power. Re-charges with plug-in wall charger (WC-152), or drop-in charger such as CSA-181
CNB-152xh 12.0v 1200mAh 3" tall, 5-watt long-life rechargeable Nickel Metal Hydride battery. Re-charges with wall charger (WC-152), or Desktop drop-in charger (such as CSA-181). Replaces original part #s CNB152, CNB242, RBP-120
CNB-152xs : 12.0v 1800mAh NEW HIGHER CAPACITY ! Battery pack is 3 1/4" tall; provides 5-watt TX capability. Re-charges with Desktop charger (such as CSA-181) or plug-in wall charger (WC-152)
CBE-152 : Battery Eliminator
CBP-262 : 6 x AA 9v Alkaline Battery Case
CBP-888 : 8xAA 12v Rechargeable or Alkaline Battery Case with Charging Port
BATTERY PACKS & CHARGERS for STANDARD, ADI, Heath, Relm, CHEROKEE, Sender, etc.
For STANDARD C228A , C528A , C628A , C558A ; HX190 , HX240 ; ADI AT200 , AT201 , AT400 , AT401; SENDER 145 , 450; Cherokee Handheld Radios
CNB-151x 7.2v 1800mAh 2" tall, longer-life Ni-MH pack; standard-size. Re-charges in Desktop Charger, or with plug-in Wall Charger. Reg. $40.00. SALE $29.95 ea. BUY
WC-151 Wall Charger - Plug-in overnight wall charger for 7.2v packs such as CNB-151x and CNB-153x. Center Pin NEG (-). $ 12.95 ea. BUY
CNB-152 12.0v 800mAh 3" tall, Ni-Cd rechargeable battery; provides 5 watts of TX power. Re-charges with plug-in wall charger (WC-152), or drop-in charger such as CSA-181. Replaces original # RBP-720. $ 46.00 ea. BUY
CNB-152xh 12.0v 1200mAh 3" tall, 5-watt long-life rechargeable Nickel Metal Hydride battery. Re-charges with wall charger (WC-152), or Desktop drop-in charger (such as CSA-181). Replaces original part #s CNB152, CNB242, RBP-120, etc. Reg $56.00 ea. SALE $ 45.95 ea. BUY
CNB-152xs : 12.0v 1800mAh NEW HIGHER CAPACITY ! Battery pack is 3 1/4" tall; provides 5-watt TX capability. Re-charges with Desktop charger (such as CSA-181) or plug-in wall charger (WC-152). Reg. $66.00 ea. SALE $49.95 ea. BUY
(Click on photo for larger image)
CBP-262 6-Cell AA case - 2" tall, holds 6 x AA Alkaline cells (9v) or 6 Ni-Cd/Ni-MH cells (7.2v). $ 20.00 ea. BUY
CNB242xh 12.0v 1200mAh 3" tall, 5-watt long-life rechargeable Nickel Metal Hydride battery. Replaces original part #s CNB242, CNB152, RBP120, etc. Re-charges with wall charger (WC-152), or Desktop drop-in charger (such as CSA-181). Replaces original # RBP-720. Reg $56.00 ea. SALE $ 45.95 ea. BUY
CBP-888 8 x AA case - NEW, 2.5" tall, accepts 8 x AA dry cells (12V) or rechargeable cells (9.6v). Provides 5-watt TX output when Alkalines are used. $ 30.00 ea. BUY
CBE-152 Battery Eliminator - 3" tall, slides onto radio. Has 12VDC socket plug at other end of coiled cord. Includes built-in noise filter. 5W TX! $ 29.00 BUY
WC-152/162 Wall Charger - Plug-in overnight wall charger for 12v packs (CNB-152 & 162). $ 12.95 ea. BUY
CSA-181 Rapid Charger - Ni-Cd / Ni-MH desktop charger for CNB-151,152,153,162,163, & ADI-600 packs. Charges in 1 to 2 hrs, w/Automatic switching to safe trickle charge mode
This series of battery is readily available from battery stores online by simply searching google, however I have found the best deals are from aviation supply companies :D .
Full credit to Towerdog for having found so many products matching this family's battery pinout / configuration. Prior to finding this post, I began searching and cross referencing batteries / adapters for a model Albrecht AE2990 AFS. After compiling a pretty nice list (separated into 7.4V and 12V varieties), I found this post matching some the models I'd found. I wanted to provide my models to add to Towerdog's list. Hopefully, our combined info can help others to find their own model on the list, and then find a related model's battery/adapters available in their own area or online, over time.
I've not researched the internal voltage specs for all models listed.
My list below was compiled based on info found, where battery/accessory sellers claimed the model to be compatible, or associated it with known 7.4V, or 12V batteries. Some models can be found under both voltage categories.
As for the Albrecht AE2990AFS, that model can officially accept 10.8~13.5V (specs show 9 x 1.2V NiMH, or 9 x 1.5V Alkaline cells). But per the schematic, this model appears to use a BA05(T?) regulator, and should be safe in accepting either 7.4V or 12V batteries / accessories (the regulator's min/max voltage is 6V ~ 25V, just for reference). This model also supports the Midland 18-821 Mobile Adapter accessory, which connects to a car's 12V power, and also has an SO-239 for connection to an external antenna.
7.4V
ADI
AT2, AT200, AT201, AT400, AT401, AT600
Standard C150, C158, C158A, C28A, C228, C228A, C450, C528A, C558, C558A, C628, C628A
Horizon HT200, HT400, HT401, HT600, HX190, HX240, HX260, HX268, HX460, HX520, HX620
JRC JHP-500, JHP-520
12V
Standard C112, C150, C158, C28A, C228, C412, C450, C520, C528, C558, C620, C628
Horizon HX240, HX241U, HX260, HX268
Alan 42 Plus
Albrecht AE201, AE2990AFS
Cherokee AH-100, AH-27, AH-50
Cobra HH-45, HH-46
Dragon AH 100, SS201, Sy101, Sy501
Eagle Spitfire 454
Intek SS 201
Magnum 1010, Magnum 1012
Maycom AH27
Titan RPSY
Reactions: ALVIN
Hmmm... Occasionally.
The advantage (paired with a mobile adapter, and magnetic mount external antenna) is the ability to setup a rig on the fly in a vehicle having very limited space, potentially while not in one's own vehicle.
The range may be something to write home about (that is, you may NEED to write home, as the range may be so limited, that only by writing will they likely get the message back home!).
But it does support SSB, and works in a pinch for local communications. :D
Reactions: ALVIN
And people actually use these walkie talkies?
I talked to one of the members here one time when the DX was running.
I was in the mobile here in CA and he was in Chicago.
Bill was on a Cherokee hand held and he was 5x5 into my RX out here.
Ya, they work.
I got a friend that uses a Midland hand held hooked to a fire stick in his Baja.
Works great.
7.4V
ADI
12V
Alan 42 Plus
Cobra HH-45, HH-46
Eagle Spitfire 454
Intek SS 201
Maycom AH27
Titan RPSY
Alan 42
Albrecht AE201
Cobra HH-45, HH-46
Eagle Spitfire 454
Intek SS 201
Magnum 1010, 1012
Maycom AH27
Titan RPSY
I currently own a Cherokee AH-50 6 meter transciever I would like to find a schematic diagram for that handheld transciever and any other info you might have . Batteries and Bulbs can rebuild the original battery packs if that helps anybody My question is is there an internal memory save battery inside the radio that I can replace where it is and what it is because my radio does not retain 500kc 1 meg offsets and is quite difficult to finnally get those set correctly there must be an internal memory save part somewhere in the circuit or on the schematic which i am trying to locate these were built in Chicago Illinoise and somebody somewhere has a schematic maybe there is a way to install a memory save tiny battery somehow
Never have seen a diagram of any Cherokee handheld radio. They were made in the far east and imported by a company called "Wireless Marketing". Pretty sure THEY were located in Chicago, but the radio should have a "made in" ID somewhere on the back or inside, along with the serial number.
Those people went bust a long time ago, so no way to reach out to them.
I found this list of radios in an ebay ad;
Compatible radios :
Alan 42 (Midland)
Alan HP53
Albrecht AE201
Albrecht AE201S
Albrecht AE2980
Albrecht AE2990AFS
Allamat 27
Cherokee AH-100
Cherokee AH-27
Commtel COM3000
Dragon SS-201
Dragon SS-301
Eagle Spitfire 454
Euro-CB Mini Pocket
Euro-CB PRO-101
Eurosonic Ultimate KH-104
Intek SS201
Lafayette Eagle
Magnum 1012
Magnum SSB-1010
Maycom AH-27
Midland Alan 42
Midland Alan 42 Multi
Midland 75-822
Moonraker Major
Northpoint AH-27F
Palstar KH6 (6m HAM radio)
PNI Escort HP62
Radio Shack TRC-1014
Stabo XH8040
Stabo XH8080
Stabo XH8082
Stabo XH9040
Stabo XH9042
Stabo XH9082
Super Radio SS30
Zodiac AH29
Zodiac P-2000
I also found a 1500ma lithium battery for the PNI Escort HP62 for $60
Search for;
PNI PB-HP62 Li-Ion 1500mAh Battery kit Plus 230V Power Supply 8.4V Output and BNC Antenna for CB Radio Escort HP 62​
Has anyone found a battery that works with the Radio Shack 21-1679? It's similar to the others, but the ears are a bit wider and taller. I've tried a bunch of different batteries that I have for my Magnum 1012, ADI HT-204, etc.
