I got a Galaxy 98V in and I smelled the burnt from when the guy’s car door opened. I didn’t hook it up and just opened it. The amp exploded 4 out of 8 mosfets Not wanting to even dick around with those boards, where the transistor controlling the fan ops blows and couldn’t care less about an amp on “the bottom” setup, I moved on. Disconnecting the amp there was a 0.5 dead key swinging 52 on a LM 700. So I decided to make it into a 99V?. Fast forward into not doing a proper alignment, there was a carrier on USB and LSB. VR17 had no effect.
So I started from the start:
Removed the diode/resistor for power adjustment and went to original.
Mic gain down
Aligned LSB to specs
Aligned USB to specs
AM way out of spec. up tp 18 Mhz.
Checked the 10.695
I apologize to Sir Mr. Lou Franklin, I never did make that crystal checker that you told me to do. Humble apology .
Replaced the crystal, realigned USB, LSB, AM.
Adj driver and finals to 100ma and 3.8v
2.5 dead key swinging 52 on AM,
30 watt dead key on SSB swing dick on SSB.
VR 17 no effect.
R 276 still in place, so the limiter is still there?
Further digging, Q39 was removed (what a turd).
Replaced the 945
AM 2.5 swinging 10
SSB 30 watt carrier.
What did I overlook?
Mic gain down
Checked the 10.695
VR 17 no effect.
Replaced the 945
AM 2.5 swinging 10
