Humor for a bit
Andy, the wind just started blowing and already the power is flickering on and off. I swear, Duke Energy...no I’ll hush.
Shadetree, I ordered them directly from Pro’s Kit. Just Google them and go to their website. I tried the superglue already, didn’t work.
Hahahahaha @Tallman
Epoxy as a rule will adhere ceramic to plastic, and silicone adhesive will work as well (learned that on an old Raytheon sub-contract years ago in another life).
Well I’ll try it. Nothing to lose, that’s for sure. I’m about tired of them spinning in the handle over what seems like nothing. Otherwise, they’re a nice little tool and I use them 10,000 times a day.
Reactions: Rwb
Jest use jb weld or any other great quality glue
Use this 1
Flexglue makes a glue
For anthing you do
The hard plastic has come off on me more than once - so the last time this happened I just went and got spares but it is a compression fitting in there and once the hole it seats in elongates, theres little to offer you except to - as others have posted - Krazy Glue or the PVC cement primer together with Krazy Glue on the shaft when you shove it back in there...
It is best if you "rough up" that shafts' smooth shaft - that is partly why it "spins" afterwards when the "seal" it had breaks. Then you can use the glue and primer as a filler to help keep the shaft from turning once it sets...
If you have a lathe turn aluminum handles out tap a set screw in the side grind a flat spot on the shaft put in handle lighn the flat spot with the set screw last long time
  • @ heartbreaker3473:
