Is resonance really where you get best antenna performance?
Now my big question and one of the most important ones, does this make a difference? Did it change my take off angle? Did it change my radiation lobes? Did it cancel unwanted currents? Did it increase the value of my s10?
Hell I dunno but it did make that s10 sexier
Reactions: tecnicoloco
Nice work!
Looks Like 12 turns of #14AWG correct?​
What was the SIZE of the dowel or drill bit to make the coil form?
It is #12 thhn. I used a piece of 500 mcm to wrap it. So a piece of 3/4 pvc would be about right. Started with 14 wraps and started clipping off a coil at a time till I went too far. Then wrapped another like it.
Tune for resonance, match feedpoint resistance with inductance or capacitance as needed. = efficient radiator. Way it is
in a 50 ohm system maximum radiation efficiency occurs when antenna (load) radiation resistance = 50 ohms and total loss resistance in the load = 0 ohms.
antenna radiation efficiency % = radiation resistance divided by radiation resistance + total loss resistance.
in a 50 ohm system resonance occurs when there is no inductive or capacitive reactance present at the antenna (load) feedpoint @ a given frequency
for frequency @ resonance, (X) reactance = 0..
No matter what anyone else would say...that is a NICE JOB.
Thank you for that pic and the basics of the construction - speaks volumes and hopefully will help many many more in the future.
Reactions: ForestRunner98
You took your nice 1/4 wave and matched it to your 50 ohm coax and gave the radio the 50 ohm load it was looking for.
Good job.
Every time someone asks a question about installing a SS whip on a mobile , that picture should be part of the answer.
Reactions: Handy Andy
So the threads popped on that antenna. Ice put another one up and didnt tighten it so much. Anyway today I'll start fresh. I'll record the antenna as I make changes.
First I'll go for x=0
Second I'll match 50ohm
Third I'll see what swr is at.
According to what I've read here, if I get 1 and 2 right that should be all you need. I'll try it and see.
Now what? Change impedance, it throws out the resonance. Keep resonance cant adjust swr.
    boog351 has left the room.
