Kenwood MC-60 on Yaesu FT-840
Kenwood MC-60 wiring detail below.
Yaesu FT840 detail below.
YAESU-FT736-FT747GX-FT757GX-FT650-FT655-FT840-FT890-FT920-FT990-FT990D-FT847
FT1000-FT1000D-FT1000MP + MKV -FT2000
PIN1 MIC UP
PIN2 EARTH ( + 5VOLTS FT847-FT920-FT1000MP-FT2000 )
PIN3 DOWN
PIN4 FAST SCAN
PIN5 EARTH
PIN6 PTT
PIN7 SCREEN/EARTH
PIN8 MIC
Both diagrams from the link below.
David
Reactions: TheRATT
While you are doing the mic I would strongly recommend doing the R2213 Resistor Replacement mod. If you don't remove this resistor from the main board then it's only a matter of time before you have major issues. I done it to mine just in time as I could see scorch marks around the resistor on the main board. If you don't know how to do it follow this article - https://www.computer7.com/yaesu-ft-840-modification-for-27mhz/ The mod is a must !
Reactions: TheRATT
