Kenwood ts 130
Bearcat
357
61
38
54
is this a decent rig and what's the price for a fully functional one? I have a chance to get one for $250
Guys that have them really like them for an older basic rig. Make sure it's in good working order, of course. I'd probably try to get the price down from $250, though - that seems high to me.
Might be still high at $200 unless it has a desk mike/or external VFO...or maybe the extra receive filter...I bought one last summer at Hamfest...
WORKING with original mic/ manual /
new power cord and original box and packing with optional narrow CW filter...
$125.00 USD
Now be advised these can be a little quirky...They have some drift...most settle down in 15-20 minutes after cold start...Mobile in cold weather area...forget it...
MOST are VERY sensitive to any VSWR above 1.5:1 due to the final PA protection circuit unless it has been modified (readjusted)... Then caution and care as anything above 2:1 for even a few minutes after adjustment can take out the final transistors.
Otherwise nice rig...receivers are a little noisy but they are 30++ yrs old technology...
I still own a couple...one with matching EXT. VFO and Spr...the other has the very RARE Digital/ with Memories VFO-230 console and matching speaker and has the 2.8 and 2.4 INRAD SSB filters installed...so they are usable rigs and simple to use...Best desk mic is the Shure 444D for desk use IMHO...never cared for the MC-50 or MC-60 mics again just me...to me they sound "Tinny" MHO again...and they have ground loop issues with some radios...
GL
All the Best
Gary
PS: I guess I should have mentioned the rig I bought (at $125 USD) did need new lamps installed in the VFO and meter and the case was a little scratched but not badly. However it did work fully on all bands.
One more note: Though they are rated at 100 watts, normal output on those is really about 80-90 watts...not a big deal...75/40m will be best output...pretty close to spec. Then you may see a little drop in power on 20m on up, 10m normally around 75 watts...with voice peaks around 50-60 PEP...this is just what I have seen from owning several TS-120/130 rigs over the years...
Again not bad little rigs...Great starter or back up rig that will not break the bank.
The price range he is asking BC, I would expect it to be very clean, full output on every band as stated above,(including 17 and 12m) all lights working plus include the factory mic and manual...maybe even the original box...
Again MHO
GL BC
Hope it works out for you
All the Best
Gary
Reactions: Bearcat
$125.00 USD
GL
All the Best
Gary
Again MHO
GL BC
All the Best
Gary
Might go with the 718
I backed out of the ts 130...going icom 718 or 7300
Huge difference in price and technology between those two. If you have the $$ buy the 7300. If your budget is geared towards the 718 then I would buy the Yaesu FT-450D. It has the features missing from the 718 and it's at the same price point.
Reactions: 222DBFL and Bearcat
