Can't remember if that's the one with plastic screws holding down the two audio-power transistors. We adopted the habit of putting a 1N4001 rectifier diode in parallel with the thermistor "TH" in the schematic. The cathode of the diode goes to ground. Found that this prevents the audio transistors from overheating and melting the plastic screws. The transistor pulls away from the heat sink and thermal runaway follows immediately. Another good reason to make sure you have the right size fuse on these old radios.
