MACO / BRUTE Seventy-Five
The resistor going to the tubes are carbon. seeing as they are hard to get + expensive, what kind do use? 238
The caps on 3 & 11 show no ohms. The one on 12, the filament shows a small number of ohms. All the pin sockets check out ok. 238
The reading on pins 3 and 11 should be an open circuit. The path from those pins to ground goes through a zener diode. The meter will read it as an open circuit.
Seems to me they ran a jumper wire under each socket between pins 3 and 11.
I would check for continuity from pin 3 on the tube that gets hot to pin 3 on the tube that doesn't.
Likeliest thing to make the tube overheat would be loss of the negative bias voltage on pins 3 and 11 of one tube, but not on the other.
Chris I think i have got you confused. I am working on a Brute 75 with 1 M2057. Recon has the 75 with 2 tubes. 238
Sorry about that. I had posted a pic of my Super75 so he could compare the two. I was not sure if the caps were pf or uf. Thanks 238
Recon needs to put a good picture of the inside of his amp so you can see how it is done. His looks odd as compared to mine. 238
