Magnum 1 Radio
Are there any known schematics for the "first run" Magnum 1 or close up photos of the component side of the circuit board?
I have one here (not mine) that a couple of SMD components "fell off" of. Big question is Where do they go?
73's
David
Below is the circuit board number of this Magnum 1.
The 2 locations where I found components missing below.
And a little “butchery” here. WTF?
The radio receives and keys in transmit but has no output. Any help is appreciated.
73’s
David
You might get ahold of Eric so you can get these correct schematic as there are now 2 variations of the Magnum 1. Looks like that one is the first production of the Magnum 1. I agree looks like an attempt by a golden soldering iron that had no business in there. Hopefully the pads and traces weren't damaged ..
Reactions: NZ8N
These radios look OK but it's just a little suspicious that only a few vendors seem to be offering them, although I did see them on copper and some other place, and a note that indicated that distribution is constrained to certain retail ops...
