I wasn't getting huffy, I being polite and not calling you a knit picking asshole.
re-quote so you don't miss this.
I was talking about Am broadcast/Shortwave that are running kilowatts of power. who would fit under your lo pass filters band pass. Now your changing the whole game by going over water I would expect the signal to flucuate reflecting off the water and I wouldnt expect the water to be still. How high is your antenna? How high do you think you friends is ? Simple explanation could be lo and high tide, 55 miles what is the radio horizon between you ?
This is truely Area 51 stuff perhaps you can film it like marconi, it happens pretty often right. You dont think the squibs over at Groton sub base is fooling with you do ya?
To me 3/4 of it is getting a accurate test result for others who search the internet for results of how a certain antenna performs. There gonna think using SSB and some of this other stuff is the way to test a antenna. They are gonna think you put the tips of antenna at same height, they are gonna think s meters can show .5 to 1 db of gain. Were just trying to get some honest repeatable results you testing one way and someone else testing another yields different results.
What are some of the thing we have learned?
1) bar graph meters are pretty much just for looks comparing signals Nah.
2) The agc of a meter does have a effect on stronger signals, it wants to equalize them.
3) The sigma and other 5/8 wave's have more gain on horizon testing in close will yield similiar results to 1/4 waves.
4) You will see better results if the test signals are further away.
5) am- fm or cw with a steady output can and should be used.
6) For accurate comparison antennas need to be mounted on same mast in same location with same coax.
7) S meters are different on every radio what you see on yours i dont see same on mine.
8) Vehicles and people can and do have a effect on signals
Now this isnt a knock on Eddie or anyone else it is about getting the correct info. Marconi has been doing these test and will do anything we ask him it seems in a effort to get the correct result as well. I am not trying to boast but I have many many many hours testing antennas trying to get max gain and nothing else
I would agree with all of this except:
#3 has not yet proven true at my QTH (in the Spring I will start all over again with the 5/8ƛ and V4k) and
#6 has only been driven as an idea hard enough to silence the opposing point of view, IMO, but in some cases completely ignores the intent in the design of some antennas.
I know that it is dangerously unpopular to think that out loud, but it doesn't change anything. Arguing that it skewers the results in favor of one antenna over the other to raise the height of the shorter antenna to equal upper elevation ignores the fact that not raising the shorter antenna up skewers the results in favor of the longer antenna. .
"and audio was about double the other antenna." Love to hear the physics explanation to this phenomenon. The photo of the two vertical radiators appear close enough to create parasitic interaction. That's one too many variables to accurately ascertain the real performance parameters of these antennas. So, another manufacturer trying to make a living and employ people, might be unduly ridiculed over bad science. Al Gore would be proud.
FM iz best
I'm just having fun. I didn't say anyone was making fun of anyone, just the bigger part of the fun was the challenges. I didn't realize Mack was genuinely miffed. Sorry, Mack. I'm harmless.
I am learning, too. And am just as interested in the truth.
I would ask a question in the interest of clarifying a thought in my head, "Why would FM not be better than AM?". It would seem on the surface of things that given AM is subject to signal fluctuation due to modulation, and given FM is not so influenced, the deduction that FM is better for testing signals seems logical. I see some merit to the idea of FM being a superior mode for testing. Why not?
I am not the scientist many of you are. I am an empiricist. My lack of knowledge is complimented and assisted by what you guys say, and do. I just see if i can duplicate what others have done. If it has been done, perhaps I can repeat it. If I fail, then why is that so. I learn with my hands on something best. For me the proof of what others have said is in whether I can duplicate it. The proof of the pudding is in replicable results.
Perhaps we can add to the list of things we've learned:
No two people express the same thing the same way.
Marconi, you are putting alot of work into these test, but i think it would be nice to seek out weak signals and switch between antennas get a signal that is barely readable and switch antennas. If a Sigma 4 has 1 db more of gain which is alot, you will never see it on your S meter 6 db = 1 S unit 3 db = .5 s unit 1.5 db = .25 s Unit. Do you see where I am going with this. If you cant copy someone and switch antennas and they are now readable you will have provenm more than us watching your meter show the same S readings.
Make your efforts count with some meaningful data. I commend you on the effort, just not your methods of comparison.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
