Maxon Mobile With Quirky Problem ???
Wire Weasel
Senior Moment
Dec 13, 2008
3,305
970
223
Have this Maxon MCB-60A junker mobile in the closet. Works fine. Don't know who made it. Kind of looks like a Cybernet chassis but not sure.
When you key the mic, there is a brief and consistent 1/4 second delay between keying the mic and when the radio engages. Same if you use different mics.
Is this the way this chassis works or does it have some kind of problem that could be fixed ??
Thanks for any help !!
Nobody's got nuthin' on this problem ??
Likely made in Korea as most Maxons were made there.... About the problem, could be a poor operating electrolytic capacitor, dried out from age and this would be the voltage 'pool' for the electronic key-up circuit. Involves the capacitor to prevent 'chattering'. Not sure of value or location.
Lag time is the period where the cap is building up voltage....
73 mechanic
Thanks Mechanic ! I've also had this same thing suggested by a local. So I looked around it again and there's so many transistors and caps in that thing I have no way of knowing which one is for TX Keying. …. forget a schematic …. I've had no luck finding much of anything on this radio and nothing at all on the board. Maybe sometime I can find some whiz around here who can point out the KT'r just by looking at it. Until then I'll just use it as is when/if I need to use it. It's no big deal. Just a cheap little backup rig I picked up for $20 to play with. Thanks again !!
