Anyone know of a good replacement mic for the above mentioned radio? I know the stock is 6 pin but I never use the channel buttons on the mic either. Are there adapters to go from 4 pin to a 6 pin?
Well the reports from those that hear me is that it sounds slightly muffled. And a upgraded mic can never hurt.What don’t you like about it? Yup..they do sell an adapter for it.
Where on the case did you drill your hole or holes?I drilled a hole in mine and it made a big difference. I've tried lots of different microphones on it, the stock microphone is still the best.
I really don't know what it is set at. Hell it could be on the low side and that's why I'm not sounding the best.For me the modded Cobra M75 works a little better but both are close. I find turning down the mic gain 1-2 clicks makes a ton of diffence in audio quality.
The element in the big housing might benefit from using some cotton to pack around it.Ok so I just got out of the truck, I figured out how to drop the Mic gain, down to 7 from the factory set 10. Also I moved the pickup from the little holder and moved it into the large opening that already had holes in it. Now I just need to get someone to answer me. I'll post up once a get a reply from someone and get the report from them.
I have one of those, it is a great mic. Clean, clear sound. Bought it from Scott's radio.ich think this is the best mic for President CB-Radios.
K-PO NM-532 Verstärker Mikrofon 6pol
K-PO Verstärker Mikrofon"NM-532" mit 6pol-Stecker: Das K-PO NM-532 ist ein Verstärkermikrofon in klassischer Bauform und exzellentem Klang. Eine rote LED zeigt den Sendezus...www.sat-online.ch
