Motorola system 500 cb 540 / cb1141
Copycat32
NNJ32
Feb 9, 2024
133
58
38
66
Northern New Jersey
Hi all received a Motorola system 500 mobile cb 1141 working great except blown modulation radio is stock/vergin.. Can't and any info on it just want to open up the audio power I'd decent to run on an amp but need to scream at the mic to get close to 80% mod whistle pushing it up to 100%
Any help would be greatly appreciated
Thank You
What microphone are you trying to use? Motorola 500 series CBs used a preamplified microphone, amplifier in the mic, getting it's power from the radio.
Reactions: Copycat32
Sure don't remember that one. Several brands had "works in the mike" models with all the front-panel controls on the mike. Just one problem. This makes the mike cord a maintenance nightmare. Takes way more than four wires and the connector will be impossibly obscure. if it breaks, tough luck.
But there's the rub. Mike cords fail more often than the microphone itself. No way to borrow a spare mike and try it. I can't find any tech info online. The only "500" model number I remember was the 555. It was a conventional mobile with a 4-pin Switchcraft mike plug.
If the cord is bad you have your work cut out for you.
Hi my other Motorola has a 4 pin mic connector.. This radio because it has the mic gain channels up and down and channel 9/19 monitor has a 10 pin mic connector. All that is working fine .. Opened nup the radio theres 3 boards old style nothing is marked and all are coated with a clear coat for moisture production..., I'm going to open the mic and see if I get any voltage while keyed up.. Is so I'll mod the mic and put a condenser element inolace of the existing element I believe nits dynamic..
Dont want to golden screwdriver then radio.. Can't find any info /schematics..
