Ok hold the presses gentelman!!
Hey Robb, while you are in there remove the final and check the weight of it. See if it feels heavy for it's size. The reason I am asking is there is a possibility (now that you mentioned the bias problem) that this final is one of those knock off ones that eveyone has seen. If this IS the case and it is A knock off final then I forsee BIG issues for those that layed out money for this things. If it feels very light then I would consider it a knock off. However from the markings on it it does look like an origonal.
And a class action lawsuit seens to be in order!
