Need Aluminum Cleaning Product Advice
Wire Weasel
Senior Moment
Dec 13, 2008
3,277
945
223
I have aluminum diamond plate bed rail and tailgate caps on my pickup. It collects some blackish and scaly residue on it. What is the EASIEST / best working cleaner for this gunk? Typical liquid paste aluminum polishes and Castrol Purple / Simple Green will clean it but requires heavy scrubbing. What works better?
Thanks!
Thanks!
aluminum paste and a high speed buffer. only thing is you will have to do it ever 2-4 months to keep it looking good.
I have always used air conditioner core cleaner (acid) on my diamond plate and antennas.
just spray it on, wait a minute and rinse it off... looks like brand new.
a LOT less work that rubbing paste and working a buffer lol
I've been doing that with the toolbox and rails on my 99 silverado since day one and haven't hurt the paint or the aluminum.
Also used to spray the pontoon boat down once a year with it and it shined the whole summer
I get my acid from a buddy who is hvac but I'm sure you could pick up a gallon at the local "do-it" center.
Hey thanks bud! I have that on hand. Will try this weekend
I use scowrer pads like you use to wash up your pots and pans. It works a treat to bring alloy back to a shine before it is welded etc. if you use a fine pad it will not score the alloy
I used Armor All Extreme aluminum rim cleaner. It takes all the gunk including brake dust stains off the aluminum wheels. It is actually an acid of some sort.
If you have a polished surface and use those acid base cleaners that strip the oxidation it can be used at too strong a mix and actually burn the outer surface and then a repolish will be in order.
At your local automotive dealer there is a polish that comes in a can and is a cotton tic that is saturated with a cleaner/polish that when applied turns the surface black and when dry and wiped away is the safest manner for cleaning aluminum.
Or you can make you own home made polish
Try some of this:
Works really really well!
    boog351 has left the room.
