Need programming cable for Icom R6 Sport Receiver
As cheap, as can be.
Reactions: Mudfoot
The only thing I can find between too fiddly cheap and the $23 unicom cable is a $7 one on ebay, but it comes with a DB-9 serial connection instead of USB.
The only thing I can find between too fiddly cheap and the $23 unicom cable is a $7 one, but it comes with a DB-9 serial connection instead of USB.
Yeah, why do they do that. I bouble a new Uniden BCT15X and it come with a DB9. So far, I've went thru 3 different USB cables, downloaded tons of drivers. Can't get it to work. It's such a pain to manually program. I guess there's still thousands of frugal hams with their 35nyrar.old PC's
Could it be the age of the drivers? I don't speak computer well, but I remember similar trouble trying to program my motorola m1225. Its been so long since that time, but IIRC, the only way I could get the CPS to work on windows 7 was to install some 16bit stuff called otya128 or wineVDM or something like it.
This is all I could find on my drive about it. Two VDM folders and an HTML with instructions. IIRC, I used the OTVDM folder because it worked better than the wineVDM one. Here is both and the HTML I used.
A word of caution. I have no clue how this will impact newer operating systems, so maybe use on an older machine you don't use every day or at least look into it.
    boog351 has left the room.
