NEEDED CLEAR READABLE SCHEMATICS FOR TRC-459
Retro CB Guy
Well-Known Member
Jun 22, 2014
806
276
Please does anybody have zoomable CLEAR close up schematics for the Realistic TRC-459 CB 40 channel ssb radio ??????????? My tech couldn't find his copy and he managed well enough to get my radio aligned up but in order to get extra channels put in which I hear is kinda risky on this radio, I need to supply him with very ledgable readable clear up close schematics and I know someone out there has it that can help me out. There is some difference between the TRC-480 and TRC-459...
Thanks, Retro 73's
Appriciate that Robb, but my tech told me something is wrong with that schematic, and I've already forgotten what it was silly me.
But I am also trying to expand upon the regular channels in this radio so if anybody can help me with that in a sure fire way please let me know !!!!!!!!
Reactions: tecnicoloco
The channel expansion works but only gives you low channels (bellow channel 1)
Also the radio is not capable of covering all the extra channels and the regular ones,drop power very quick.
My 2 pesos
Tecnicoloco
Actually the channel expansion mod will give a range from 26.785 to 27.595. Andy is correct that power falls off quickly, so the real usable range is 26.875 to 27.505.
- 399
Unit 399, that's perfect range of channels for me bro.... But my tech is telling me it's too risky and fragile of situation for him to do it ! He doesn't seem to think, there are tried and true and reliable documents for doing extra channels for the TRC-459.....
Hmmmmmm guess I'm stuck in limbo ...
Here's my experience with expanding the TRC-459.
You can't just run long wires from the original crystal's holes in the main pc board to a convenient switch you can reach from the outside of the cabinet. The wire length will throw the radio off frequency. The error will be so much that the trimmers you use to set channel center on the clarifier won't travel far enough to compensate.
The added wires will also make the radio even more unstable than it was on the stock 40 channels. It does tend to drift. Any mods to the oscillator circuit make the drift worse. Especially any mod that serves to increase the clarifier's range
When you finally go to the trouble of using diodes or a relay to switch the new and old crystal you will find that the new crystal is hard to get centered on the clarifier, even if you provide a separate trimmer cap for the new crystal. The original crystal is not correlated to the marked frequency with the standard "32 pf" compensation. If you order a custom-made crystal using that spec, it won't want to line up with the radio's original crystal.
Even if you get one mode lined up on the clarifier, the other two modes will be offset to one side or the other from that one.
The only cure I can see is something like the Galaxy Viagra kit. Not only does it have the added crystal for a new band, but a separate trimmer coil for each of the radio's 3 modes, one set of 3 for each new band.
And fitting a hand-built perfboard with all that stuff on it into this radio and getting it mounted close enough to the crystal's location on the main pc board is a whole 'nother challenge. Good luck with getting it crammed in there.
The true cost of modding this radio for upper channels will pay for a used radio that came with 6 bands.
Another one of those "Yeah you could, but why?" kinds of a mod.
Thanks for the reply Chris ! Insightful info as always... I look forward to seeing you next appointment this month. It should be interesting cos I've got 2 now with extra channels added with a few minor things needed done to both, so guess I'm the lucky one.
Cheers and all the best 73's, Retro
  • @ heartbreaker3473:
