PAL VFO PLUS “H” question
Crambone
Well-Known Member
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
58
I have a H model PAL VFO Plus with a 16.115 crystal in it. Can I change the crystal to a 16.420 and use with my Mark III ?
The listing for "H" says the output frequency is 16.115 MHz. This suggests a crystal frequency 5 MHz lower, 11 MHz plus a little.
If your crystal is marked 16.115, I'll be surprised. That would get you an output frequency above 21 MHz.
Sounds like the "H" version should work on the SSB Mark 3 transmitter the way it is. A tweak to the dial-calibrate trimcap should be all the conversion it would need.
