Palomar 200x problems.
Hicountry
New Member
May 26, 2021
3
When amp is powered up it blows the filter capacitor.have went through 2 it's the same one each time .have had no problems up to now .i left the positive side loose on the new capacitor to see if it would power up and it did.so I soldered the capacitor .put all the tubes back in and decided to use a variac to try to power it up when I got to 25v I could tell it was about to blow another capacitor by the way the variac was laboring.i shut it down and decided to take the two wires that fed the filter capacitors loose.turned the power button on tubes did not light up nor did the off and on light.i am not good at trouble shooting one of this amps.but did spend four hours checking diodes chokes wires and so on.any help would be appreciated.thanks
