Palomar 225 w/2 MRF 455's
fastfreddie1269
New Member
Dec 9, 2025
29
3
3
60
I recently aquired a Palomar 225 linear amp (has black label & 2 MRF 455 pwr transistors, not blue label). It has a burnt (so badly I can't read the value) 2 or 3 watt resistor right next to the transmitter input. Does anyone know of a schematic for the amp? Or what other components maybe affected by the resistor burning? Thanks!
Btw, here area couple pictures of the Palomar 225...
That resistor is in series with the radio's drive power to the transistors. A pair of MRF455s only needs about ten or twelve watts peak to smack them fairly hard. Even a wimpy AM CB does half-again more or twice that. You'll be hard pressed to find a radio that small. The resistor serves two purposes. FIrst, to bleed off some of the radio's excess drive power, and to hold the amplifier's input impedance somewhere close to 50 ohms. The input of an amplifier should fool the radio into thinking that it's connected to an antenna with a low SWR. The resistor increases the amplifier's input impedance, hopefully to pin it near that 50-ohm mark. That resistor took it on the chin when somebody used a radio with two final transistors, or some other excessively-large output circuit.
That amplifier sure looks like the ones a friend was selling back around 96 or 97 when yours was probably made. The transistors are marked with a 1996 production date. The amplifier was probably built soon after that. I'll look to see if any diagrams of those amplifiers can be found next time I get to our shop.
Hi, I was asking about a schematic for a "black label" Palomar 225 a while back and was wondering if anybody was able to find it? I have one for blue label 225 & they def aren't the same! Thanks
Hey, I just dug out this Dynamo 175 amp that I was playing with
over a year ago, adjusting the bias, by-passing RX pre-amp,
correcting the RF input circuit. I got it working good.
I always wanted the proper schematic.
and I just found the schematic this morning! maybe?
"AUTOMATIC SIDE BAND" "CLASS AB1"
Palomar 225
as mentioned, I have the Dynamo 175
also known as a White Tornado 225, Shooting Star 225
Here is my older post. it looks like resistor R14 was changed to 100 ohms.
and I disconnected that screwball input circuit, and just have one
resistor there, and I feed this with a China made Cobra 148.
took a look over that schematic diagram.
but the bias circuit on this diagram is messed up.
at relay RLY1 - 14,15,16 just a drawing mistake. ?
and that feedback through the 27pF capacitor from the
amplifier output. hmmm!
so will pull the board out, and do some continuity tests.
so the PALOMAR ELITE 250 is the same circuit as I remember. ?
I had a few of them here from a guy in town. I gave them all back
to him. I was too busy at the time.
so fastfreddie1269 we will get you rolling here soon.
