President Jackson BLACK (PRE ASC) external S meter Tap
Spyder280
Apr 13, 2020
12
3
13
48
I had a Euro Jackson Black with the external S-meter jack. I sold the radio that had it but had to buy another.
This one does not have the jack. I thought I documented the location to tap.
IF someone could provide that information. It will be used with the MD-4 S meter.
I cannot believe I couldn't find it.
Thank you in advance !
May not be as simple as it seems. The first paragraph of this page warns that tapping into the existing meter circuit may cause calibration issues. Has a solution involving an op amp.
Edit: it look like the jackson has an unused op amp inside you could use for this.
where pins 3, 2 and 1 would be 5, 6 and 7 respectively on IC2
