Radio network topology
Just_A_Random_Guy
New Member
Jul 4, 2019
Hello, I have a question... "Is there a product / type of product available that you know of that would allow multiple radios operating in the same band to utilize 1 antenna? An example would be, if you had 8 radios wanting to monitor 8 frequencies a couple Mhz apart.
I understand that this may preclude you from transmitting on this setup directly.
I would need physical radios, as opposed to SDR.
whats out there? whats good? pros/cons, any information greatly appreciated
VHF.
You can hook two or three radios together but each one reduces the signal a little. Eight radios would reduce the signal quite a bit, possibly to the point that you won't hear what you normally would.
There used to be a guy who sold a device on eBay that had relays in it and all four radios would be connected together on receive. When you keyed a mic on one of the radios, the relays for the other radios would shunt to ground to protect the front end of the radios. I sent him a message through eBay a few months ago and asked him if he would make me one but he said he didn't have any more boards to make the unit.
Chris
VHF.
For receiving only:
http://www.stridsbergeng.com/multicouplers.html
