RCA CO-PILOT 14T305
ClaimJumper
156
75
38
63
So far I'm just putting a power connector in this radio and then testing it. This is just something I noticed. If this microphone ever goes bad the owner is screwed! You can't change the channel, the volume, or the squelch on this thing without the microphone. But they put a knob on the front for a dimmer. LOL
I go all out on any 02A Cybernet, but that’s just me. The two push buttons would be mounted below the MOD indicator. The RF gain would be the volume, and the DIM knob would become the squelch. The 4 pin jack would be wired for any Cobra mic.....While I’m at it, incandescent bulbs would be changed over to LED’s.
Reactions: doffo
Well. So far the microphone is a little bit of a problem. Channel up and down buttons only work intermittently with a lot of pressing involved. Also so far, no sound from speaker or external speaker that I plugged in. A little bit of scratch in there though so I'm hopeful on that. Took the mic apart and I'm going to clean all the switches as good as I can with contact cleaner. We'll see where it leads from there. I'm not going to dig too deep into this thing without that microphone working properly.
Reactions: TM86 and doffo
I would convert it to a 4 pin, then put some push buttons on front for the up/down fuction. :) But that is too much trouble.. :P I tried selling one last year here locally for a whopping $5 and nobody bought the damn thing. :D
Yeah. They're not really worth that kind of work. Unless I really like them and I'm keeping them myself.
Reactions: doffo
