RCI-2980 Final Replacement
Nomadd1776
New Member
Sep 24, 2025
6
Got a RCI-2980 (non WX version) that a final blew on. Im planning on replacing both of them, along with the bias diodes, the 1w resistors and the pots. My question is about the MV1Y bias diodes. I have searched on here and other forums and not sure what way I should go. I have read that I can use 1n914's diodes, epoxied to the boards just like the MV1Y's are, and I have also read that I can use 1n4148's without them having to be on the boards. Will it make a difference in which ones I use? Is what I read correct and can I use either the 1n914's or the 1n4148's or should I try to find the MV1Y's? Thanks in advance for any advice.
Good deal. Thanks for the info. Ill post some pictures when I do the replacement aftet the finals get delivered. Thanks again.
I have SMD 1N4148's. I could make replacements that screw to the heat sync like the originals so the diode body is flush against the heat sync. I have no idea how they would perform compared to the originals, but that could easily be tested by bolting one next to an original and heating them together watching the VF with a scope on a long timebase. And I could borrow an original from my washington to do that.
I'll back-burner this thought unless someone says they want me to. Sounds fun though.
Reactions: AudioShockwav
We are going to have cheap replacements for this part very soon. I just ordered 500 BAV99W's. I think I will sell pairs of them (on the PCB) for $5.
Since these are like the 3-terminal ones in my washington that have two diodes in them, they will be able to serve as a single junction MV1Y or a dual junction MV13YH by simply adding solder across two pads. I will pre-drill and etch a few dozen pieces this weekend while I wait for them to arrive.
edit: heres the plan. when I get them, I am going to monitor the bias current on my washington as it warms up. Ill key down into the dummy load for a specific time and watch the temp on the thermal camera. I can plot the bias current vs temp. Then I will put one of these diodes in and do the same and see if the bias remains acceptable over the same temp swing. I will probably have to readjust the bias for the new diodes, but I am guessing they will track the same. We are going to find out. I'll report my findings in a separate thread.
Have you considered using HG 2SC1969's or a matched pair of MRF475?
That is a nice radio to put cheap garbage parts in! It's like putting a Briggs & Straton engine in a C5 Corvette! LOL
It is worth putting a two decent bipolars in.
I think the downfall of the world is due to Americans and their throw away mentality. Let's put the cheapest POS parts we can make work into something that could easily last another 100 years if we actual repaired it properly and maintained it!
Reactions: Nomadd1776
I removed the old parts, but due to my eyesight getting worse as I get older, I think Im gonna wait to install new parts till I purchase one of those microscopes with the monitors so I can see better when installing the new parts. But I thought that the 2SC2312 was a better final than the 2SC1969. Which one would you guy say would be the better ones to get? Thanks in advance for your advice.
The difference is too small to worry about. People who obsess over a 15 or 20 percent power difference are impressed. But the S-meter at the other end of the conversation won't move more than the width of the pointer if that much. My practice has been to use the 1969 and not worry about a fractional power difference. The 2312 had a reputation as being slightly stronger, but not enough to urinate on in practice. There is a 1 ohm quarter-Watt resistor in the base circuit of each final. Since a common failure mode is for the final transistor to short between collector and base, this part is at risk along with the bias diode and trimpot. Just be sure to set the idle current (bias) for each. I leave each final's base lead standing up not soldered yet. Transmitting on sideband with zero mike gain, probing the foil pad for each base lead will reveal the "zero voltage" end of travel for each bias trimpot. That's my preferred starting point once each base lead is soldered to the pcb. Bad juju to key it the first time with that adjustment set to max current.
Best of luck with the seeing aids.
I appreciate the advice. I did order up a set of of the HG2312's and i have pots and resistors. Just need to order a new driver and then solve the sight issue so I can replace the componets. I will post some pics of the repair when I get it completed.
    boog351 has left the room.
