RCI RHF-618 New Export Base Station
This it direct copy and Paste from the cloppers web page::
R10-10121 Ranger RHF-618 10 & 12 Meter Base
[R10-10121] $489.99
Click to enlarge
10 & 12 Meter Bands
Large Display
Improved Receiver Design
Variable Output Power Control
Active Frequency Scanner
Receiver Clarifier (±0.5kHz)
99 Programmable Frequencies
Noise Blanker/ANL Circuitry
Programmable Repeater Offset
Public Address Feature
Additional Features
4.3" TFT LCD Panel
Soft TOUCH Panel buttons around the display
IT IS NOT A TOUCH SCREEN
RCI-2950DX reliable electrical specs
Self Bright and clear display
Built in clock and date
Auto switch of priority for communication
Auto CW Key
USB Load background images
An improved receiver: designed for increased sensitivity and image rejections.
A double FET balanced mixer: for improved receiver inter-modulation ejection.
New power supply protection: and temperature compensation for Improved stability and reliability over wide temperature ranges.
Surface mount components: for increased resistance to shock and vibration.
Improved display lighting: for easy reading in a wide range of light conditions.
Variable Power Output from 150 watts to 2 watts - great for PSK-31 operation.
This Is direct copy and paste from R&R`s web site
Ranger RHF-618
10 & 12 METER BASE HAM RADIO
2 YEAR WARRANTY
SPECIFICATIONS:
AC/DC POWER 110VAC OR 13.8VDC
MODE: CW/FM/AM/USB/LSB
FREQUENCY RANGE: 24.8900-24.9900 & 28.000-29.699 MHZ- UNMODIFIED
FREQUENCY TOLERANCE: .005%
FREQUENCY STABILITY: .001%
13.8 VOLTS DC
METER FUNCTIONS: BAR GRAPH READS RELATIVE RF OUTPUT, RECEIVE SIGNAL STRENGTH, MODULATION, AND SWR.
OUTPUT POWER: VARIABLE AM/FM--------------10 WATTS�UNMODIFIED
SSB------------------ -----------------25 wattsWATTS PEP�UNMODIFIED
CLASS B AM MODULATION
RECEIVER SENSITIVITY: AM-------0.50 MICRO VOLT
FM-------0.25 MICRO VOLT
SSB------0.15 MICRO VOLT
IMAGE REJECTION: -50 db
ADJACENT CHANNEL REJECTION: GREATER THAN 75db
CLARIFIER: UNLOCKED +/- 5KHZ�UNMODIFIED
CONTROLS:
FREQUENCY SELECTOR, VARIABLE RF POWER, MIC GAIN, ON/OFF-VOLUME, SQUELCH, RF GAIN, CLARIFIER, MODE, NB/ANL, ROGER BEEP, SPLIT FREQUENCY, PROGRAM, MANUAL, SHIFT, DIM, SWR, SCAN, MEMORY, ENTER, LOCK, UP/DOWN SWITCHES.
AMENITIES:
8 DIGIT FREQUENCY DISPLAY, VARIABLE AM/FM OUTPUT POWER, SWR SYSTEM, ROGER BEEP, 10 MEMORY CHANNELS, SELECTABLE 100HZ-1KHZ-10KHZ-100KHZ OR 1MHZ STEPS, SPLIT FREQUENCY OR OFFSET FREQUENCY, ABLE TO SCAN YOUR PROGRAMMABLE CHANNELS, ABLE TO LOCK YOUR KEYBOARD, CHANNEL NUMBER OR FREQUENCY DISPLAY. 6 PIN MIC JACK FRONT MOUNTED, EXT SPEAK JACK, EXT CW JACK, USB CONNECTOR, WITH TFT SCREEN.
2 YEAR FACTORY WARRANTY ONLY.
PHYSICAL SIZE: 4-3/4* 11 1/4* 13 1/2
Now, this is the best picture I have of the radio, Look at the power supply, my eyes are not as good as they used to be, but that looks like 12 volt output @ 8.5 Amps
I say 10watts AM/FM and 25 Watts SSB...
Click and view the enlarged view, I agree with AudioShockwave, gotta be a 10/25 watt radio
powersupply.jpg​
copper says its 25wt on ssb 10 am,no touch screen.
They have it plainly shown on there web site as a 150 -2 watt radio.
I will post it again
From Coppers web site:
this was copied July 3, 2011, at 11;32 hours from there web site.
If they are telling you on the phone that it is a 10/25 watt radio, and advertising it as a 150 watt radio on there web site, it is a bait and switch routine and a lot of guys are going to be pissed off when they order a 150 watt radio, only to get it and find out it is not.
It would not surprise me if this is the case.
And for the record.....
...that power supply won't handle the output of the radio once it has a peak & tune. The Galaxy DX2547's had the same supply, and in the mosfet versions of that radio, the supply couldn't handle the single mosfet final after a peak & tune... sure ain't gonna handle a dual final mosfet radio.
Stuff is getting so cheaply made it's ridiculous.
And between Ranger and the distributers, they don't know what to market this radio as? Touch-screen or no touch-screen? 25W or 150W? Who knows? :confused1:
Yet another joke of a radio from Ranger.
~Cheers~
I been trying to get ahold of one but all the distributors are sold out. Hopefully range will get more in later this month.
Power testing.
watch
I didnt believe it would have touch screen techonology but i thought maybe they had a beefy switching power supply that could power 150w. only 52w fully tuned up
