Ok so the last guy that was in the mic installed cheap capacitors Ann installed backwards I followed the direction and had the problem.. I checked my + 3 B and cs-1 and saw the problem.. I'll have to reverse all the electrolytics .. UghI used 4.7 I place of the 5 10 in place of 15 22 I place of 25 all nitchicon caps put the 470l resistor back in same results going to check the tantalums diod and fets I replaced the. O1 it helped.. I got this off ebay someone was defenitly in side.. And it has a chrome ssk head had to rewire and resolder everything.. Cleaned the contacts replaced the faulty volume control..
