Replacement for SO42 mixer IC
These guys claim to have them in stock:
I've never used that vendor, so buyer beware, etc.
Are you quite certain this chip is bad? It's probably the single most-reliable part in the Uniden 40-channel and RCI-made radios .
RCI was using a tiny surface-mount pc board with pins to match the old chip and a TDA6130 smt mixer chip on it once supplies of the original part dried up for good. Just because the factory can't obtain them 10,000 at a time doesn't mean you can't find someone with dozens or a few hundred on hand to sell. Can't imagine it would be worth anyone's while to counterfeit a part this cheap.
I'll predict that a closer look at this radio's transmit mixer will reveal that one of the two inputs to the S042P is missing and the chip itself is probably okay.
