Retevis HS4 frequency adjustment
Hawkeye351
Jun 27, 2021
871
788
103
58
Anyone know where the transmit frequency adjustment is on the HS4 boards?
Also, a local friend of mine asked me if there's any way to add the VFO windup to the Retevis HS4, I told him I wasn't sure and would have to look over the schematic first. However, I can't find a scheme for this radio, and the anytime 5555 shows np transmit frequency adjustment.
Search for AT-5555 frequency adjustment - it is the same procedure as the newest versions will apply to the HS4. It is menu driven. Here:
HOWEVER - the chances of a new HS4 being off-frequency are extremely low. This almost never happens. These radio are rock solid stable. What issue are you having?
The HS-4 has no VFO support, the firmware doesn't allow for it unfortunately. It is stuck in CH mode with some ability to move +/- with the clarifier control, in a VFO-ish way.
