Sams PhotoFacts Collection
Anytime... Dan
I thought you might like a follow up on the radio repair. Open B+ winding in transformer, got lucky with the small wire broken at the large wire that exits, successfully repaired. 1 leaky electrolytic in power supply, replaced all of them. Paper caps replaced. Found 1 open resistor and 3 resistors that had changed values way out of tolerance, a gassy 6AQ5 tube, and an IF transformer with grid winding having the internal SM capacitor open. Replaced with an external capacitor. Someone also tried to mod the S/RF meter switch so the S meter would work in RF position and I restored that back to factory wiring. I put too many hours in this one but I was determined to fix it.
Thank you again for providing the service info.
MOG
MOG
So the radio is working now? Thanks for the info on the repair... Dan
Reactions: PY2ADN
Been a while since I bugged you for a Sams but I need one for a Midland 13-898B.
Thanks in advance...
Let me check...
Here you go.... Sams info on midland 13 898B... Dan
Reactions: PY2ADN
