Scratchy microphone
codeman
Recovering Crackerhead
Jul 10, 2011
874
1,713
153
So I bought a astatic red devil Mic and had it wired for my old uniden grant radio, I didn't have the Mic very long before it started scratching when I key or unkey the radio. How can I get rid of this problem? I'm ready to toss that mic. Other then the scratchy sound I get told the audio is loud and clear.
Thanks
Been told it makes a lot of scratchy sounds when I key up to talk and when I unkey. I can hear on the talk back as well. I had no problem when using a different Mic.
Like w9cll said, probably a dirty switch. I don't know if you can spray contact cleaner inside the switch but after removing the battery, some deoxit with 50 keyups followed by fader lube would be my preferred method, but I've never had this problem. works great on stereo switches though.
sometimes just using it a lot is enough to clear it off. open it up, pull the battery and put it back together and start pushing the button. try it 100 times and put it back together and try it on the radio.
try wiggling the cord around first though. it could be a loose contact at the connector, or a bad solder joint, or break in a wire in the cord.
They're nice mics, only one I'll run mobile.
maybe you're just keying too slow, try pushing the button faster.
How about replacing the switch with one like this?
Thanks for the help. I will get some contact cleaner and see I'd it works. Seems to be a good Mic otherwise, I just wish the slider on the side didn't move so freely.
