Short Mobile CB Antenna Advice
Im thinking look and compare a k40 to a wilson lil wil.set swr to the channel you use most, 300 watts is pushing a 3 ft stick imo.but if your radio is maxing at say 50 watts pep it will work fair.but like i said my wilson is working fine but i buy a new 1 it could be no good . Many great suggestions above.
I'll be more than happy to build you a dummy load on a stick to your specifications.
6 gauge copper wire should handle whatever you want to put into it.
If you make a cap hat on a short coiled antenna like that and make it resonant on 27 MHz, it'll be far from a dummy load on a stick.
  • @ Hambones amps:
  • @ ShadowDelaware:
    Hambones the entire amp section would have to be retuned, and the rf transformers re wrapped.
