Solarcon A99 for 10 meter plus
bhayles
Jul 2, 2014
181
25
38
mountains of N Georgia
juicymaters.com
If I want to use an A99 for 10 meter but don't want to ruin it for 11 meter by cutting 11 inches off the top (per the A99 instructions), can I get at least useably close to 28.300 to 28.500 by adjusting the tuning rings towards the top of the antenna, thus "shortening" it?
The A99 I use doe snot need any cutting for 10 meters.
It presents a decent impedance up to 28.500mhz, also works on 11,12,and 15 meters no antenna coupler required.
I do not have any ground plane radials installed on the A99.
Use your HF rig and check the vswr on that A99 before you go to cutting it.
Anything under a 2:1 VSWR is good.
Reactions: 738 and S&W357
My A99 works from 10 - 20 Meters with a Tuner but I can run it from 11 meters through 10 Meters 28.500 without a Tuner so call me lucky but I love it. As the SWR is withing tolerable limits ;)
Reactions: S&W357 and Low_Boy
I tuned my A99 for 27.500. It covers the cb band up to 28.500 with out much of a problem. With tuner I can drag it down to 17 but its not very effective that low. Mine actually works on 15 without a tuner. swr 1.3-1.5
If you just leave the antenna as it is and use a manual tuner, you will get 10, 11, 12, and 15 meters. Might not have the best specs outside of 11m; but it will still work just fine and contacts can be made easily. I wouldn't mess with the rings unless one has an antenna analyzer.
Reactions: 738 and Wire Weasel
just put up my a99 with ground plane kit put rig expert meter on it and it was at 31340. tuning table shows cutting 18 inches off , i am worried about cutting the antenna knowing anything i cut cant be put back!
any help will be appreciated
K6SDM
steve
My A99 gets all 11meter and all 10 meter and if I remember correctly it may do up to 20 meter. The internal tuner on my radio tunes it. I have to say the antenna has been great. Also I forgot to mention I Have no ground plane kit.
K6SDM
steve
Something is not right with the above....
Antron 99 with tuning rings correct?
What frequency did you test on?
Is that resonate on 31.340?
Cutt 18 inches off don't sound right....
Let's figure that out before you cut anything.
Reactions: K6SDM
