For true soldering of these difficult metals, Super Alloy 1 melts at 350 degrees and works with a soldering iron. Larger jobs requiring more strength can use Super Alloy 5 that melts at 600 degrees with a bond stronger than the parent metal. I'm sure the paste works well in many applications but just offering other possibilities if more strength is required.
I found the Super Alloy rods very useful in rebuilding an old PDL II antenna. All the pressed on aluminum ends for the orbital gamma match received a nice bead around them. No more bad VSWR when the wind blows.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
