ssb external counter reading
1iwilly
Sr. Member
Dec 7, 2008
924
657
103
64
quick question when using an external dosy fc-50 freq counter for usb channel 20 =27.2060?? and lsb =27.2040 ?? 148gtl side mike
using a 1000hz
You really need to use a hardwired counter on SSB. Inline counters need a stable carrier to properly read the frequency.
It could also be that the radio drifts a little when you change frequency.
Ah, is the FC-50 the one with the tone generator in it?
If so, you add 1 kHz to the reading for USB, subtract one for LSB.
Pretty sure that's a straight counter that doesn't perform any arithmetic on the reading.
Is this the one you can press a button and freeze the display after you drop the key?
