I run a 4 square array with fantastic results ....
I would like to hear more about this, also a short list of the sources you used for info when putting this together would be nice.
Nice to see something different now and then.
Nice to see something different now and then.![]()
.... antenna distances need to be exact so do the coax lengths feeding them because its all about the phasing so its uber-critical. ....
.... I'm using 4 Imax 2000's 18' to the feed point 36' apart. ....
That's one reason I asked for more info.
Most of what I'm seeing with google searches says 1/4 wave apart, radioreddz seems to have went with a full wave. I was wondering if radioreddz knows something google doesn't.
Also another question that google hasn't answered, will feeding them all in phase give an omni pattern?
ADD to that list ON4UN low band dxing books, several in print and the Christman forced current method of phasing.
Would not hurt to have a good ARRL antenna book hands also, and a calculator.
https://www.eznec.com/Amateur/Articles/Simpfeed.pdf
http://home.earthlink.net/~w6rmk/antenna/phased/christman.htm
If I'm reading this stuff right it looks like you can have good directional gain and good omni performance from one antenna system, should be quite a capable one stop solution if set up right (for a single band of course). At the very least it will make for some good reading when I have more time to kill, I'll have to save these links for future reference.
Thanks for the replies.
It sounds like a practical nightmare to stack 3 verticals. I appreciate some people are into this simply because you can, that's fine of course, whatever floats your boat.
Would it be significantly better than a Gain Master on the top of the pole in practice ? Or an extremely well set up high quality 5/8 wave ? Or a 3/4 type ?
Seems like 3 x as many potential issues as well. 3 x the coaxial losses.
5.4dB ?
http://www.dx-antennas.com/Stacking.htm
I would not bother myself (but that is me of course and you are not me) and put a nice omni up top with superb coax and spend time ensuring the VSWR was the lowest obtainable.
As an aside and I quote from the above article:
"In my case I still need a few of those Pacific DXCC so the best solution for me would be: to place a high big single yagi and put my money more in the height of the antenna then the antenna it self. (according the ARRL the main angle under which pacific is coming through is around 2 degrees, Europe is around the 20 degrees for me and Africa about 10 degrees.) I've I was a contester and participated in a African contest a stack would be a better solution for me."
Interesting to note that DX can be coming in at a mere 2 degrees...wow...almost directly at the horizon. That is when a clear empty sight line between the horizon and your antenna is going to pay dividends. I would focus on using an antenna that can see that aperture. A very good omni, well set up, at great height (you have good mast height) may just well see that. Given what I have managed myself on a £100.00 Chinese 10-12M radio I would go with a Gain Master, that antenna works the longest DX distances extremely well even on one of the cheapest HF radios you can use.
For all the theory, proof of the pudding is in the eating.
Well thanx to all the reply`s and in put , I have talked with someone in the past that had three A99`s up and they where happy with them so I am going to give it a try and with the in put ppl have add`d it will help .
It`s that time of year to get the outside projects done .
