stock mikes
1iwilly
Dec 7, 2008
924
657
103
64
well, time to update my stock mikes elements is the higher the impedance the better response and clearer sound. I have 4 of them 1 reads 500 ohms 3 reads 450 ohms 1 reads 150 ohms i'm looking at to new elements 1=
  • Sensitivity: -70+/- 3dB (at 1KHz)
  • Impedance: 500 ohm
  • Frequency Response: 300~6KHz
  • 2nd one=
  • Element Type: Dynamic Moving Coil
    Pattern: Cardioid
    Impedance: 500 Ohm
    Freq. Resp: 100 Hz - 12000 Hz
    Sensitivity: -76 db +/- 3db
    S/N Ratio: >65 db
Reactions: Rwb
That's not a problem.
You need electret capsule and small mod inside radio.
Add 1 resistor and 1 capacitor.
and where can a lost soul find such valuable info if you don't mind directing me to that so call info i only use cobra radios 2k and 148 gtl
Reactions: Rwb
That Cobra?
Reactions: Rwb
just order the electrec mike got one for now to experiment
I obtained the Threesome offering from likely the same fleebay seller. Sponge was far too large to properly orient electret elements in D-104 Mic Head. Manufactured disk from ABS plastic and drilled holes through the 1/4" ABS thickness. Perfectly aligned elements to front facing, with a little depth to spare.
The seller was not at all forthcoming as to specifications of electret elements.
The kit was successfully installed with the included voltage regulator, presumably a resistor, to trim 9V down to the required voltage; I'm don't know what that voltage is.
Reactions: 1iwilly
Astatic D-104 “G” stand, (non amplified mics) electret condenser upgrade kit
Astatic D-104 “G” stand non- amplified microphone Hi-Fi electret condenser upgrade kit. This will replace the original crystal or ceramic condensers that break down over time with a powered condenser that will provide crystal clear loud modulation. These will actually create a power mike swing with a non amplified mic. This kit will work on any D-104,(except “K” model mics), however non-amplified mics will require mounting a 9v battery in the base of the mic to power the condenser. The battery connector is included with this kit. The kit requires basic solder skills for installation. It is very easy to install and comes with detailed instructions. The kit includes a prewired electret, a custom built mounting fixture, a voltage regulator with backfeed protection capacitor, and shrink tube for insulation. These kits are fully tested before shipping and guaranteed to perform as described
A capacitor it is not resistor. "Custom built mounting fixture", that's ROFLMAO funny. Useless is closer to the truth. You'd be lucky to get a single electret to mount face forward let alone 3 or 5 with this so called "custom build" oversized foam sponge.
A 3" hole saw cut produces 2 7/8"D perfect fitting disk of 1/4"h ABS; for a
D-104 mic. Customizing the ABS disk along its periphery to accommodate the 4 front and back mounting screws and you have rock solid mounting of 1,3, or 5 electret condenser mics.
Had that "Custom built mounting fixture" not exceeded 1/2" in thickness it might likely would have been acceptable. Considering the D-104 depth, not including front face and back plate, ring depth does not exceed 1/2". Clearly not a lot of thought in the "Custom" design past what it looked like on paper.
