That is odd, but then again it is not i dont think the extra length is taking away, but for him to put that mutch more then you, he has to be running a amp or unless you have a high SWR!! i myself, would try 108 foot of coax an see if you cant tune your antenna down some more, im sorry i cant give you a possitive answer, but it is weird like you say!!! To me it sounds like a Antenna setup problem, because if yall are doing the same numbers in watts, yall sould not be that much different, and for him being a little hight then you will not make up a 4 s unit gain, sooooooo, ponder a little on this and figure it out, im sure you will!
</p>
</p>
