Switching between antennas
Working good so far
Sent from my iPhone using Tapatalk
Cool. So are you still using your old two position switch in-line to change between the G5RV and Antron for your ham rig?
73,
Brett
Not anymore.
I have my HF rig and 11 meter radio on on side of the antenna switch. On the other side, I have the g5rv and the antron 99. depending on where I have the switch it swaps them out. so, if I am on 10 meters on the hf rig, I can use the antron because it works better. however, if I am on another band, I can switch to the g5rv. I can do all of this without having to disconnect and reconnect anything.
Not anymore.
Which is what you wanted to do.... GREAT! :thumbup1:
73,
Brett
  • @ heartbreaker3473:
