  • Retevis is giving away a new RA89R for Father's Day! Click Here for more info!
SWR Mystery
Riverman
I Support WorldwideDX.com!
Nov 12, 2013
3,072
3,443
273
SWR at SWR meter:
1.6 on CH 1
1.1 on CH 40
SWR at radio:
1.1 on CH 1
1.6 on CH 40
Shouldn’t they be close to the same?
what antenna are you using ?, do you have a dummyload to check both meters ?
if the meters read ok you probably have cmc,
from Walt Maxwells "another look at reflections"
" If SWR readings change significantly when moving the bridge a few feet one way or the other in the line, it probably indicates "antenna"current flowing on the outside of the coax, or else an unreliable instrument, or both, but it is not because the SWR is varying with line length"
SWR at SWR meter:
1.6 on CH 1
1.1 on CH 40
SWR at radio:
1.1 on CH 1
1.6 on CH 40
These readings are acceptable - but what are you trying to do - what are you up against?
Wilson?
Francis?
NMO versus SO-239 versus Lug to Lug?
1. Do not trust internal SWR meters.
2. Do not trust external SWR meters unless you verified it's readings.
3. Measure SWR close to antenna or with 180° coax.
Or:
Forget all above and use VNA.
Mike
Reactions: Robb
Wilson?
Francis?
Yes. I’m good with the numbers. Not one who goes nits to get a 1:1.
Was just curious of the numbers being reversed at two points 6’ apart. (3’ jumper from radio to amp and another 3’ jumper from the a p to the SWR meter.)
    boog351 has left the room.
